Linked Revit File Greyed Out in Visibility/Graphics
kjskoog
kjskoog
I have linked in two Revit Architectural projects into a host project. I want to show the annotations and fill regions etc. I go into Visibility/Graphics, then the Revit Links tab and the links are greyed out. I want to change the Display Settings to by Linked View. I want the plan view to be linked into a plan view. Both the linked view and host view are named the same with identical levels. How do I get the linked view to not be greyed out?
Thank you.
Kory Skoog
Project Manager
Kory Skoog
PM/BIM Manager
brettgatti
Are you using a View Template for this view?  If so, you may want to remove (uncheck "Include") the V/G Overrides RVT Links category so that you can control it individually per view or make the change that you want in the View Template itself.
kjskoog
That did it. Thank you. I knew is was a simple click somewhere.
Kory Skoog
Project Manager
Kory Skoog
PM/BIM Manager
David125
I am at a loss for where to find that check box, can you do a screen capture of it?
