Linked Models Including Sheets/Views
BigPicture045
BigPicture045
I am linking a garage to a main building via Revit links. In the garage Revit file, I have set up the floor plan and elevation views and set them up on sheets.
Can these linked garage sheets/views be seen in the project which they are imported into? I'd like to print from one file and not have to combine PDF's manually.
No.
You could however make the Link display "By Linked View" in a Parent Project View. FWIW.
You can create views in the main file and set the garage link to display by linked view and pick a view from the linked view list.  You will have to name views, crop views, and place then on sheets manually.
