revit and autocad automatic shutdown
4 ANTWORTEN 4
Nachricht 1 von 5
BIM_Dreamer
304 Aufrufe, 4 Antworten
i tried to open my autocad and revit but there is an error "the license manager is not functioning or is temporarily installed. autocad will shutdown now" and have follow this link but doesn't work. please help any inputs will be appreciated. ithank you
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
4 ANTWORTEN 4
Nachricht 2 von 5
rxi.gg
als Antwort auf: BIM_Dreamer
Hi Good morning,
you have a specific forum for this issues:
https://forums.autodesk.com/t5/subscription-installation-and/ct-p/3001
Thank you
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 5
thamizhz
Please clean your %temp% files. also reinstall your revit software. it may be license subsciption issue.
Nachricht 4 von 5
BIM_Dreamer
als Antwort auf: thamizhz
doesnt help and tried already. thank you
Nachricht 5 von 5
RobDraw
What have you done to try to fix the license manager?
Rob
