@tmccar wrote:
No, it only has the World UCS
Okay. Let's go about this instructional another way. Open the RVT file with the Linked CAD. Is the CAD Link where it should be? I'm guessing it is. Now select the Linked CAD, press "Shared Site" under its Properties and then press "Change" next to "Record Current Position...". Now press "Duplicate" (under "Location Weather and Site": "Site" tab) and create New Site name (call it "Shangri-La" for this exercise) and press "OK" -- and "OK" again to close out of the "Choose Site" dialog box. Now, go to Insert: Manage Links: CAD Formats and highlight the CAD Link line. Press "Save Position".
Now Remove the Link, Save the RVT Project and Close it completely (just go with me here). Now Open the CAD File, Type "UCSMAN". Do you see "Revit 60 -Shangri-La"? I'm sure you do. That's your "Shangri-La" Shared Site position/orientation within the RVT you just closed out of.
Now reopen the RVT you just exited. You don't see a Link in it; right? That's because we removed it. All is not lost though. Go to Insert tab: Link CAD and insert the CAD File (with the "Shangri-La" Site) into the Project using "By Shared Coordinates" . You should now be prompted to pick a Shared Site. Pick "Shangri-La" and "OK".
Is the CAD Link now positioned and oriented exactly the right way relative to the RVT Model -- and maintain that relative position and orientation no matter what you do with the views' orientations?
