Hello everyone
I have an issue printing form Revit on custom paper size. It seem that the ''viewport for printing'' in offsetted from the paper (594x810 mm).
This occurs both for pdf plotting as well as from printing on paper.
I don't know if there is something wrong with the block title since I created it. That's why I am attaching it as well.
What would be the cause for this issue?
Regards
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
hmm.. I can't find reference planes in the title block family editor. Instead, I pinned the reference lines, dimensioned the parameter from the reference line to the edge of the paper and still the same result.
Did it work for you?
Also, can you elaborate on the second point?
Just delete the reference lines you don't need them...dimension directly from the Title block lines
Alternatively drag the reference lines and make them shorter than the Paper Height/Width
