Linked autocad topo drawing not showing in 3D Layout
Message 1 of 19
Hi I have linked and set up a topo drawing from Autocad.
The drawing is only showing in 3D and not in any other views.
Does anyone know why this is?
I have checked the Visibility Graphics in the 3d view and the linked drawing is not in the imported categories tab.
Replies (18)
Message 2 of 19
Sahay_R
If it was linked you should see the DWG in VG in any view.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 19
When you link the DWG in, DO NOT check the "Current view only" box.
Message 4 of 19
That's what I thought.
See screenshots
Message 5 of 19
I might of done that. Does that mean I have to do import it again? or is there a way around it?
Message 6 of 19
Sahay_R
Nope. Just go into VG in the view with the Invisible Link. Fix the box. All will be well.
Rina Sahay
Message 7 of 19
Sorry I don't follow.
It looks like I have clicked current view only when linking the cad drawing.
Is there a way to reverse this?
I'm not sure how to 'fix the box' under VG.
Message 8 of 19
If you checked that box when you linked it initially then you have to delete the link and relink. No exceptions.
Message 9 of 19
Sahay_R
It worked for me. I linked with the box unchecked in plan view. Then went back in, checked the box, and it was wonderful.
@Anonymous go into VG>>Imported Categories. It should look just like the picture.
Rina Sahay
Message 10 of 19
You linked with the box unchecked so it is okay and you can see the DWG in any views you wish.  He linked with the box CHECKED so it does not work because the CAD become 2D detail lines, not 3D model lines.
Message 11 of 19
Sahay_R
@ToanDN - it works either way (or maybe I have the proverbial Ghost In The Machine)
Rina Sahay
Message 12 of 19
@Sahay_R  No it does not.  You can try to link a new DWG in with the box checked and see if you can see it in a 3D view.
Message 13 of 19
Sahay_R
Just did. For the n'th time. See 'em both!
Rina Sahay
Message 14 of 19
Attached are a blank Revit 2017 file and a CAD file.  Please link the CAD file to the Level 1 floor plan view with the "Current View Only" box CHECKED.  Then go to the 3D view and see if you can turn on and see the CAD link.  Upload it back if you can.
Message 15 of 19
Sahay_R
An RVT is worth a thousand words......
Rina Sahay
Message 16 of 19
Sorry I don't believe you linked the CAD file with the box "Current View Only" checked.  Please try again.
Edit:  attached is the file with the CAD linked in with the box checked.  Please turn it on for the 3D view without re-linking it.
Message 17 of 19
Sahay_R
Tsk tsk tsk @ToanDN
Such a nasty suspicious mind!
Rina Sahay
Message 18 of 19
Please, you DID NOT check the very box we have been talking about since forever.  Screenshot from your cast.  Check that box and come back.
Message 19 of 19
Sahay_R
Yikes! Point conceded! All hail!!
Rina Sahay
