I've got a problem/question. I'm working on Revit 2016 doing MEP. I'm importing a structural revit file into my Mechanical template and this strucural file got a point cloud in it. My problem is, i can't find a way to hide it.
I've tried finding a point cloud tab or a case in visibility and graphics that could make it disappear. I've tried looking on the internet but there's nothing that make me believe it could be done directly in my Mechanical template. You're my last chance !
Thank you for your time and your responses.
Gelöst! Gehe zur Lösung
Gelöst von chrisplyler. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Warm welcome to the Autodesk community!![]()
The extents of a point cloud visible in a plan or section view are impacted by the View Range.
To modify the visibility and graphics of point clouds in each view, use the Point Clouds tab in the Visibility/Graphics Overrides dialog.
Graphics panel
(Visibility/Graphics). In the dialog, click the Point Clouds tab.The Point Clouds tab contains the following columns:
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
If that doesn't work, try this:
1. Select the imported structural file.
2. Activate the Query tool on the ribbon.
3. Click on the point cloud.
4. When the dialog box pops up, click the Hide button.
Thank you @Viveka_CD and @chrisplyler for your answers it really helped me. I didn't knew the query tool but it's a good feature. Have a great day both of you.
Good to hear that you found the posts helpful!![]()
You have a wonderful day!
Viveka CD
