Link IFC not showing - Revit 2017
mairh_tsek
Message 1 of 13
mairh_tsek
I have two questions:
1. I am trying to Link an IFC file in Revit 2017. It seems that the IFC file is linked (see attachments) but I can't see the IFC file in my project (I have turned on all the V/G). Do you have any idea?
2. I want to link the IFC in order to check, if I will be able to see the shared parameters that I have assigned in each element. Do you know if it's possible? To select an element and to see its parameter?
Thank you in advance!
Maria
Replies (12)
Message 2 of 13
Viveka_CD
Hello @mairh_tsek
Setup the template and/or the views to show the linked files. Go to the view, type VG or VV (for visibility graphics) and change the settings as follows:
From your attached files - 3.png you had set it up to host view, please change the setting to show 'custom'
User-added image
Let me know this solves your visibility issues.
Message 3 of 13
mairh_tsek
Hi @Viveka_CD ,
Unfortunately I have the same result!
Do you have something else to propose to me?
Thank you!
Message 4 of 13
Viveka_CD
Hi @mairh_tsek
Did you check the export settings and made sure that the IFC mapping file that you want to use for the export to IFC is loaded and is actually on your computer? If not please copy the .txt file from the other computer and load it on yours.
Message 5 of 13
mairh_tsek
Hello @Viveka_CD ,
Yes I test it..
Message 6 of 13
bwang-tecoustics
Can you paste your screenshot again. Can't see your setting. I have the same problem now. The IFC file is loaded but not shown.
Message 7 of 13
mairh_tsek
I solved this problem going to the V/G > Revit links > Custom and put in the Phase Filter: "Show All" and in the Phase: "Latest Phase"
Message 8 of 13
Viveka_CD
Hi @bwang-tecoustics
Please go to your visibility graphics - Revit links tab and follow the same settings as shown above and try as suggested by @mairh_tsek
Let me know if this helps resolve your issue.
Message 9 of 13
Thanks mate, your help was precious. Why the ... it's not directly clear
Message 10 of 13
Perfect!
Message 11 of 13
sie
Observer
Observer
Hi @Viveka_CD and @mairh_tsek
I hope you can help me as well.
I have a RVT 2018 model where I have to import an IFC (RVT 2019) model into.
I have tried the same method as the mentioned solution in this thread, showing latest and all phases.
In the RVT file which it generates from the import of the IFC, I can see both 2D and 3D.
Pictures below
Regards Simon
Message 12 of 13
nrodriguezJ42S3
Observer
Observer
Thank you so much. I can't believe such a simple solution is hidden so deep.
Message 13 of 13
uriasP2NYL
Community Visitor
Community Visitor
Thank you, it's so much easier than i thought!!
