Link File Visibility Graphic
HL_Aminul
HL_Aminul
Hello everyone,
I have a query about the visibility graphic for a link file.
how do i change the visibility graphic of the floor and parking in area number 2 as per image attached.
i've tried to use filter with comment parameter, but it does not work.
any solution will greatly appreciated.
ennujozlagam
what do you mean by visibility graphics? are you referring to a view range? thanks
HL_Aminul
not view range,
i would like to make the surface pattern is hidden.
syman2000
If you set your link to hidden for pattern, it won't do much since you've set the model to shaded or consistent shade. What you need to do is set the pattern to Solid White color.
ennujozlagam
you can go to VG > revit links > display setting > custom > model categories > custom > and you can overrides your surface pattern. thanks
HL_Aminul
Thanks @syman2000 .
its worked.
@ennujozlagam your feedback will change the whole plate ...i just wanna change only the bottom part (area 2) highlighted in prev. image attached.
anyway...thank you guys.
