!Link Autocad - some blocks are corrupted
mairh_tsek
mairh_tsek
Hello all,
After purged the useless elements from the autocad file I linked it in Revit. I see that some blocks are corrupted (image - 2) in revit but some others not (image - 1 ) . I tried to explode the blocks in the editor block but the result is the same.
Do you have any idea how can I fix it ??
Thank you in advance!
hmunsell
an you post the DWG you are trying to link into revit?
Howard Munsell
mairh_tsek
Thank you for your answer,
I tried this approach :
'If you do not have access to AutoCAD, an alternative is to start a new Revit project file, import the drawing, and fully explode it. Then export that view back to AutoCAD and import it into your Revit project.'
But when I imported again the 'new' autocad in Revit  I had the same problem. So I linked directly the Revit file (with the imported and exploded .dwg)
