- Mute
- Permalink
- Report
In AutoCAD, it is possible to link an Excel Spreadsheet to a drawing, open said spreadsheet from AutoCAD via OLE, make edits to it IN EXCEL, and then the spreadsheet in AutoCAD is updated with the new information when the Excel file is saved...
THIS IS WHAT I WANT
My company lists out system classifications, labeling methods, etc. used in the field using a simple Excel Spreadsheet. I want to link this spreadsheet into my Revit file so that I can put this spreadsheet into our Sheets that are eventually printed for construction documents. Why is this a hard thing to do? I don't want to import data. I don't want to import formulas. I just want to link a simple spreadsheet into Revit so that the data in the spreadsheet is visible in Revit and updated whenever the spreadsheet is updated. I feel like this is not a difficult task, and I may even try to make a simple Revit add-in that will do this.
Does anyone know how to do this? Or perhaps a workaround that would effectively do the same thing? I would really like to avoid just taking a screenshot of the spreadsheet and importing that into the project onto a sheet, changing the screenshot anytime the spreadsheet changes.
