link a revit model site
tam_chungthithanh
tam_chungthithanh
how can split the plane and material assignment of the file link model site in revit
SteveKStafford
You can override the appearance of link file via the controls found in Visibility/Graphics. If what you do isn't present their you might be able to override by element via the right click options assuming you can tab/select the element(s) you want to alter.
You can't change the substance of elements defined in an external file, you'd have to change the element in that element's file directly.
Steve Stafford
