Link a Model line to a detail line
Camilo_Reinales_5TUW6MUD3VN2
I am having an issue where I need a line to show above everything in a view, but the family I am using uses a model line, (Its a CODE Measure line for a Code Analysis Fire Safety Plan)
Is there a way to either:
        1. Have a Live link between a Detail Line where they both move at the same time when either is modified
or
       2. Have a Detail line added to this family, so I can control/arrange the line so it displays on top of everything else                  (Crosses walls and modeled elements on a view)
syman2000
Why not create a line base family that will show both model line and detail line? See attached
I believe I have a line base family, but when used in the model, it visually goes under modeled items.
syman2000
You have to add projection line
Afterward you can control where the line exist base on the projection height
Alfredo_Medina
Maybe you can draw some reference planes, so that you can see them in every view at the same position, and then align and lock lines to those reference planes.
