lineweight in plans and elevations
basma_salman
basma_salman
I would like to know how to show the line weight in plans ( the closest object should be displayed in a thick dark line and for the far objects should be displayed in lighter line weight), same situation in elevations,
however, in elevations I know I can use depth cueing and the line work tool, is there any other way to show line weight in elevation? and how to show it in plans?
Replies (15)
You just described what we do with Depth Cueing and the Linework tool.  Why can't you use them?  Or, Override Graphics by Element, Filter, Category?
Depth Cue doesn't work for plan views so you have to use linework tool, or stack several plan views with different view ranges, override the lineweight for those view to meet your need. None of these are practical.
basma_salman
because it is not a practical way to use line work tool and go through all of ur elevations or plans views and do each element by a time, it is just a time consuming
Would it be okay to change the tone instead of lineweight? For example, from 100% black to 75% to 50% to 25%.
I would agree that it's not "Practical"-work.  It's more akin to "Art"-work.  But, if that's what you want to do, Revit does have tools to do it.
basma_salman
you mean to change it for each view or  from where should I do it? object style?
I don't see how VGOs or Object Styles will be of assistance  to you here.  VGOs BY ELEMENT is what you would use to selectively change the display of certain elements in a view.
Object Style is a Global Setting, not a View Setting. Through the View's Visibility and Graphic Overrides, we can override the Object Style just in that one View.   But that's BY CATEGORY.  That's not what you want. You want to select particular "background" and "foreground" elements and change the the way they look in the View.  Therefore, you would use Graphic Override BY ELEMENT.
basma_salman
all solutions or tools provided by revit would not be practical when we are having big project with lots of views, I can not imagine going through view by view and adjusting the line weight using the line work😓
Me neither. Lot of work.  Does it pay?
If you are okay with using various tones instead of lineweights to illustrate the depth then it is rather easier, no overriding or object styles involved, and all can be done within one view.
basma_salman
it is just giving me a headache, can't believe a powerful software like revit , can't work properly when it comes to lineweights
I don't how any software could do what you want.  It's totally subjective.
If it isn't subjective, then tell me how it is not. This could be a Dynamo Routine -- if there is a "routine".
basma_salman
RDAOU
On how many plan views do you need to apply this? and how complicated are the layouts?
RDAOU
One of the improvised ways to show depth before "Depth Cueing" was introduced to elevations was to use filled masking regions with invisible lines then adjust transparency as per image below...some use transparent 3D masses...easy and doesn't take much time
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
