Lines of trees
Lines of trees
Lines of trees
hi,
I'm looking for eas way to create lines of different trees.
www.TechRoom.bg
If you need to quickly create rows of trees, use a custom curtain wall family. A curtain wall family is more versatile than a line based repeating component because it allows you to:
  1. leave out certain trees (by setting the cutain panel to blank)
  2. use different types of trees in the same row
  3. space out the trees in different ways (regular or irregular intervals)
  4. use straight lines, curves, and change directions within the same row (with greater control of what happens at the intersections)
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
