Where can I find a list of Category IDs?
Kimtaurus
Advisor Advisor
Kimtaurus
I'm looking for a list of ID's of all the Revit categories (7-digit number).
I have found a good list already, but there are still some categories missing. For instance: conduits and several other Systems categories.
Revit Category ID's
I'm updating a .txt file based on the Dutch NL/SfB coding and would like the codes arranged according to the Revit categories, when assigning the SfB codes as an Assembly Code. The .txt. file is similar to UniformatClassifications.txt (with Category ID at the end of each line).
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
L.Maas
Have look at THIS blog post on the buildingcoder website. It has some code to get these numbers. Further down the post there is also a text file containing many of the category id's.
Louis
Please mention Revit version, especially when uploading Revit files.
L.Maas
As addition, It is also possible to use Dynamo to get the list (and if needed exportedl)
Louis
MichaelEmngler2285
I didn't find the Get Categories in Dynamo 0.9 which was released a few days ago.
Could you please detail a bit on how to produce a Category list in Dynamo with some equivalent node?
Thank You,
Michael_E
Kimtaurus
@MichaelEmngler2285 The "Get Categories" is a custom node, probably downloaded with a package.
Open Dynamo > Under Library click Add > Search For a Package.
Or you can try a create your own script.
MichaelEmngler2285
Can you be more specific?
What is the Package's name?
Have any clue regarding the structure of the script?
Thank you,
Michael
L.Maas
It is part of the Bakery package
Louis
