Lines not showing up
steadfasthomeplans
steadfasthomeplans
On one of my floors the lines aren't showing up.
In the visibility graphics all the lines are checked. What else do I need to do to see the lines, its only in this level that I can't see the lines, they work on the other levels.
syman2000
Here are several suggestion
1. Check if the line is placed in workset that is not visible
2. Check if the line is drawn at lower than the view range. Set the view range depth to unlimited
3. Check if the crop view is hiding those lines
steadfasthomeplans
It was the view range, thanks!!
AzWoodWarrior
The infamous view range! Does that mean that the work plane was set lower than the extents of the VR? I was having the same issue except in an elevation view. The work around I had to use was put it in 3d and wire frame. Not ideal, but a deadline is a deadline
