Lines can not intersect each other. The highlighted lines currently intersect.
danielPKKNP
3,667 조회수
22 답변
1/23 메시지
danielPKKNP
Hi all Revit users, wishing you all a prosperous second half of 2022 !
Just as my title says, I keep getting the same error msg as the following.
"Lines can not intersect each other. The highlighted lines currently intersect".
None of any perpendicular lines actually run past through the other. They are perfectly co-incident.
I try to make the ends of the perpendicular lines just touching without the end points connected co-incident.
As well, I use the trim tool to trim out the outermost parts of the lines mentioned above.
Does not work but only displays the same error msg.
Then, Revit picks other lines and says the same error msg.
This is fantastically annoying.
What can I possibly do ?????
Those of you who know, please please please share your tip as detailed as possible !
Greatly appreciated in advance !
3,668 조회수
22 답변
답변 (22)
2/23 메시지
Lines of what?  A profile?  A region/floor/ceiling... boundary?
3/23 메시지
I suspect you have overlapping lines (count them) or a rogue line exists out of the view range.
4/23 메시지
RSomppi
Ironically, you need to be more detailed about your issue. Examples would be extremely beneficial.
5/23 메시지
danielPKKNP
Oh, pardon me. This happens in Drafting View when I try to make detailed components with Filled Region.
With just model line, it's all good. It is just in the drafting view with the filled region command.
6/23 메시지
danielPKKNP
7/23 메시지
A boundary of a region must be a closed loop, no intersecting lines, no gap.
8/23 메시지
danielPKKNP
yes, no gap, and definitely closed loop.
9/23 메시지
OR...
10/23 메시지
danielPKKNP
Example as the following.
the framing boundary of the image above is not a part of the model.
It is from Paint in Windows Accessories folder.
11/23 메시지
RSomppi
12/23 메시지
What about intersecting lines?  Share a screenshot.  Or, select all the lines in the editing mode, copy to clipboard, cancel out, paste to create a set of lines in the view, then share the file here.
13/23 메시지
See that orange line? Delete it.  Rinse and repeat if necessary.
14/23 메시지
danielPKKNP
Thank you for your consistent and quick replies guys.
I deleted as you said, the lines are 7 in total but still tells me the same error msg. (sigh)
15/23 메시지
RSomppi
That does not look like a closed loop. The vertical line in the middle cannot be there if you want the fill to be the entire large rectangle. You can draw over the region afterwards.
16/23 메시지
Red line forms a closed loop.
17/23 메시지
danielPKKNP
What I did was putting two separately drawn squares put together side by side.
Deleted the center line (which happened to be an overlapping line).
Drew a line on the same spot as a separately individual line.
Still can't allow to have two separate regions but placed side by side, right next to each other ?
18/23 메시지
danielPKKNP
Getting me closer to understanding how Revit interprets.
Thank you.
19/23 메시지
How is that a closed loop?  Get rid of the vertical line in the middle.
20/23 메시지
RSomppi
You still haven't showed us the desired result.
