Linear dimension cannot place
Message 1 of 9
Cannot place linear dimension in horizontal and vertical between walls.
another all dimension can place in walls.
Replies (8)
Message 2 of 9
Avaris.
Please, show us a picture of what you want to achieve.
Message 3 of 9
constantin.stroescu
Are you sure they a parallel? they have to be in order to place the dimension line. Otherwise , try to place the dimension between one wall and a POINT on the other wall or use a Reference Plane parallel to the first wall.
Constantin Stroescu
Message 4 of 9
Linear? Do you mean Aligned?
...Just Tab-Tab-Tab. It isn't plainly obvious when it snaps to a point, but it does. Takes a little finessing.
Message 5 of 9
Yes, opening floor on Level 1. Linear Dimension cannot place the dimension between wall or wall centerline.
another aligned & angular dimension can place the dimension between wall on same floor
Message 6 of 9
Yes, Linear Dimension. another all dimension on same floor can place.
Message 7 of 9
That's not the way Linear Dimensions work.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-DocumentPresent/files/GUID-F52741E0-A4C2-451D-BDD2-6C31C62D0C19-htm.html
Message 8 of 9
this was I doing, but I cannot pick point of linear dimension.
Message 9 of 9
Avaris.
Are you clicking on an point? Or are you trying to annotate two lines?
Linear dimensioning works only at points, make sure you click on the red marked points:
