LINE WEIGHTS NOT CHANGING
Message 1 of 11
Hello, I am trying to change my line weights for cut lines and projection lines and I have tried changing them on object styles as well as on visibility graphics but my changes are not being applied to the line weights. I have also tried changing the color and line pattern just to see if it works and it actually works but the line weights just won't change. What should I do.
Replies (10)
Message 2 of 11
SteveKStafford
Object Styles govern globally unless Visibility/Graphics overrides are invoked. So if you assign pen 5 to something in Object Styles but change it to Pen in 3 in V/G then Pen 3 is what you should get. If someone has used Override Graphics (right-click option) then changes to OS or V/G won't change that element's appearance.
Also the Lineweights table governs the thickness of each "pen" at different scales. This way as a view scale gets coarser lineweights can get progressively thinner to avoid creating muddy drawings.
What category element(s) are you trying to change?
Steve Stafford
Message 3 of 11
hmunsell
Revit has a Hierarchy of overrides. Object styles and Visibility Graphics a re pretty low on the list. check this chart out and start checking some of the items 7 and above (see attachment...).
Howard Munsell
Message 4 of 11
Turn Thin Lines OFF.
Message 5 of 11
I haven't applied any overrides and I have even checked for filters just in case but there are none applied. I am trying to change line weights for walls, windows, doors, furniture as well as entourage ( a shipping container that I downloaded from revitcity).
Message 6 of 11
How do I do that?
Message 7 of 11
I haven't interfered with any of the other options, I went directly into the object styles option and went back to visibility graphics after it became apparent that changing the line weight in object styles wasn't working.
Message 8 of 11
@Anonymous wrote:
How do I do that?
Type "TL"
Message 9 of 11
rabieebbe
Observer
Observer
Graphic Display Options -> Model Display -> Silhouettes: <none>
Message 10 of 11
chenyuh
You saved my life
Message 11 of 11
rabieebbe
Observer
Observer
Haha, it was super tough to figure this one out. Glad I could help 🙂
