Line Weights not changing
Message 1 of 11
I am creating a family with nested families. I have a section cut detail component which I want put in a family. I inserted the detail and saved it as a family and nested the same to another bigger family. When I nest it there, the line weights are not able to be reduced. Is there any step which I am missing or should I manually draw each component, which I think is not generic.
Please advice.
Replies (10)
Message 2 of 11
dzanta
verify the following:
1.  Object Styles dialog box settings for detail components
2.  Subcategory of lines created if necessary
3.  Object style is added inside the families
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 11
I am still getting the thick lines Smiley Sad. I tried changing the line weights in the families.
What I did was I imported the detail item from the revit libraries and put it in one family and again nested these two to another family and finallly loaded to a project. I changed the object styles, created sub categories but when I load it to a project The line thickness doesn't change.
Please can you help me out here
Message 4 of 11
Keith_Wilkinson
Can you post it?
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 5 of 11
dzanta
if you can attach the families, we can look at it for you.
Message 6 of 11
Thank you. I am attaching the nested family. Whne you load it to a project and place it on a wall. ( A wall based family). And do a section cut. The detail lines are thick. Please tell me how to control that and I will be good.
Thanks for the help! @dzanta
Message 7 of 11
Keith_Wilkinson
In your family : Nominal Cut Lumber-Section.rfa the boundary line type is set to Heavy Lines - I think this might be the cause you your issues.
Maimonides
Message 8 of 11
@Keith_Wilkinson it worked!!
Should I use the same concept for walls and any other line weight problems. I would like to create a sub category of line weights and apply them to every job. Is that possible?
Message 9 of 11
Keith_Wilkinson
Generally everything in your project is controlled under object styles.  If you create new sub categories in your families they will ultmately appear there as well.  I try to keep things as consistent as possible and don't go creating unnecessary sub categories.  Keep it clean and simple and you should be fine.
Maimonides
Message 10 of 11
I think we have a similar issue - if we take a family and in our project file join it to a wall, the family takes on the line type properties of the wall. Is there a way for the family to join without changing line weights? Is this also an object style issue?
Message 11 of 11
What kind of family?
