- Mute
- Permalink
- Report
I imported a .obj file into REVIT 2024 through the import CAD option in the Insert menu. The imported object comes into Revit as a generic model and can be cut by the section box and in a section. However, the section cut line weight of the object does not show up in the section view.
I would agree that this is a problem with the imported obj file; however, the line weights of the object show up in the plan view.
I have attached screenshots of the plan view showing the line weight of the object in the plan view and the screenshot of the section view, which does not show the line weight of the cut object. I have also attached the Revit file.
Please bear in mind that I have also tried changing the visibility graphics of the line weights for the object.
I would be grateful if anyone could help with this problem,
Thanks in Advance.
