Lights rendering as orbs through glass
sbhillGLZ6D
sbhillGLZ6D
Hello all,
Whenever I render a view the lights I am using render as orbs of light emanating from the bulb. However, the catch is that they only do this when viewed through glazing.
I have attached pictures below for reference. These views are rendered at Medium, Artificial and Exterior Light. The light is 'Pendant Light - Linear - 1 Lamp 48" - 120V' hung at 1' from ceiling.
Thanks!
sbhillGLZ6D
Here are the results from some additional tests I did. I also used the 'Ceiling Light -Flat round' to check if it was isolated to one light type.
L.Maas
Can you post a relevant portion of your project so we can have a look?
Might have something to do with the light in the family or maybe some material settings.
-Which Revit version?
-Local or cloud render?
-What happens when you use different render settings settings?
-What happens when you use a different light source in the family?
-What happens when you use a different light family?
Louis
Please mention Revit version, especially when uploading Revit files.
sbhillGLZ6D
Thanks for your reply. I have tried a couple different types of lights, all with strange results. When I try to pull part of my model out into a new file, the problem goes away. I'd prefer not to attach my whole model here, but are there specific settings I might want to check? I've tried different levels of render quality and interior/vs exterior etc.
aRcHiTeCt.JM
@sbhillGLZ6D
... you need to render in better settings
... like high or best
.... here a render in draft mode
... here a render in best (not finished)
.... but you get the idea
... the reflections and refraction on glass are getting way better
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Is your light fixture using a material with Self-Illumination properties?
