Wall sweep in wall type Attach top
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1651 Aufrufe, 5 Antworten
Fingers and eyes crossed someone can help!!
I have created a wall type with a basic horizontal cladding sweep. Problem i am having is that i can Attach top/base the wall to a roof but the sweep does not cut with it. please refer to image attached. I have tried overlapping sweeps but the roof apex just looks rubbish!!!
Is there any hope???????
Thank you for taking the time to read/think about this.
Ben
Tags (3)
5 ANTWORTEN 5
Nachricht 2 von 6
Erense
als Antwort auf: Anonymous
Try using the profile as a wall reveal instead of a wall sweep.
The wall reveal does interact with the wall when attached to the roof;
Maybe create an extra layer on your wall type to create the same materialproperties.Reveal2.pngReveal1.png
See if you get the wanted result like this.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Nachricht 3 von 6
L.Maas
As alternative solution mentioned by @Erense , you can create the reveals inside the wall itself.
You also could consider to not model it at all and just use a material instead.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 6
Try Editing the Profile of the Gable Wall instead of Attaching it.
Nachricht 5 von 6
als Antwort auf: Erense
Morning Edwin,
Perfect matey, created a quick blocky reveal to test and it does work.... just have to make a detailed one now 8O)
Funny thing Revit, I honestly thought a sweep was the way forward and hadn't even considered a reveal.
Attached is an image for anyone else who is interested.
Anyway, Thank you,
Ben
Nachricht 6 von 6
als Antwort auf: L.Maas
Thanks Louis,
Yes the reveal worked. Had used a material before but really wanted some shadow to be cast with the cladding to give it a better render.
Cheers for helping
Ben
