Lights not placing
Lights not placing
j_mcpherson172
Observer Observer
Message 1 of 11
Lights not placing
j_mcpherson172
Observer
Observer
I am having a hard time placing light fixtures in Revit. It will only let me place in the 3D view but not the ceiling view. My teacher and I messed with the view range and that didn't work, I can't hide my ceiling because Revit won't let me get it back after.  please help ASAP!
Replies (10)
Message 2 of 11
jay_colc
Are you placing them in a Ceiling Plan?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 11
j_mcpherson172
Observer
Observer
Yes and no because in the ceiling plan is where I can edit them and I'm just plotting them randomly in the 3D model because that is all that Revit will let me.
Message 4 of 11
mhiserZFHXS
This may not be the main point of the post, but what do you mean Revit won't give you back your ceiling after you hide it?
I'm fairly certain this is a visibility thing. I'm guessing your ceiling is already hidden in your RCP so you don't have anything to host your lights to in that view.
Message 5 of 11
j_mcpherson172
Observer
Observer
My teacher and I tried the visibility settings and that didn't work. I have only been using Revit for a month now so I am not 100% sure how everything works.
Message 6 of 11
jay_colc
Check if the lights are ceiling hosted or level hosted, this usually causes issues.
if ceiling hosted they need to be in a ceiling view as they will attach to this.
if level based they will be offset from this level and then usually go outside the view range and not visible in a floor plan
Jay Colcombe
Message 7 of 11
mhiserZFHXS
Go to your RCP, and click the Reveal Hidden Elements icon. Look around for your ceiling. I'm guessing its hidden.
Message 8 of 11
HVAC-Novice
Please be clear what exactly is going on. Hosting to what? Ceiling, or level, or what? What type of family (hosting type, or share the family).
Visibility may be another issue. If  you can't see the ceiling, you can't place on it. Or are they placed (visible in 3D), but just not visible in your RCP view?
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 9 of 11
If you use face based families then choose Surface instead of Vertical Surface when placing them in a ceiling plan.
On hiding the ceiling, why would you need to do it?
Message 10 of 11
Are you saying that your teacher messed up the RCP View Range and you don't know how to correct it?
Message 11 of 11
revitnation
Make sure your ceiling is a compound ceiling type.
