Solved by danielchibueze313. Go to Solution.
There are several possibilities so I suggest you post :
1. the lighting family file to this discussion
2. A screen capture of the properties panel of an instance of this light in you project that doesn’t render.
This will allow others to test your light fixture.
-luc
@danielchibueze313 wrote:
My spot lighting in revit 2008 does not emit light when i render with raytrace. Please who knows the reason.
Is it supposed to emit light? How do you know it's not emitting light?
Share the spot light family. Check and see if the light hide behind glass object. Often the light won't show because the glass maybe set to opaque material or by category.
