- Mute
- Permalink
- Report
Hello All,
Attached is a fixture family for ceiling mounted exit signs. I did not create it but would like to modify it. My goal is to add model lines that are set to a work plane at a specified distance from the reference plane. This allows me to make it visible in Plan Views such as a Life Safety Plan with out adding additional components in the model or worse yet,,,, using annotation symbols on views..... lol.... I have done this on other fixtures and it works nicely but this one is more complicated. I set op a named plane as you can see in the file. That will allow me to account different ceiling heights and still have the plan view items be below the cut line. My issue is that the ceiling view reference level items are all annotation details that you can only have attached to the reference level. Further, they have visibility parameters so that I can control how it appears... IE double face sign with 2 arrows or single face sign with no arrow, etc., etc... I would like them to be duplicated, but as model lines so that a can set them to the new reference plane. I also need the new model line items to have the same visibility parameters. That way when insert a family type in the model, the ceiling view graphics and the floor plan view graphics look the same..
Is this even possible? I tried to convert the detail items to model lines .... obviously didn't get very far... lol Any help would be appreciated.
