First, restart and see if it's still not working [just to make sure]
Check if you have a system variable pointing at the server.. if not, leave
it and add the value in your registry.
Use RegEdit to add the folowing key
HKEY_LOCAL _MACHINE\SOFTWARE\FLEXlm License Manager\ADSKFLEX_LICENSE_FILE
for the value you add '@designs2001' if there already is an entry or want to
use multiple servers [god knows why] just add it like this: '@designs200;
@designs2001'
Your machine now should be able to see the license server... if there's
still no connection, contact your Reseller for apropriate support. good luck
"philrusso700" schreef in bericht
news:844670.1083679518965.JavaMail.jive@jiveforum2.autodesk.com...
> I am getting a message "no connection to license server could be
established" I have other machines in the office that work fine. Mine gets
that message. The server name is designs2001 and I can ping the server no
problem in a cmd window. any help would be greatly appreciated
