Libraries missing
Libraries missing
coastguy84
Message 1 of 18
Libraries missing
coastguy84
Just trying out revit for the first time but I cannot find where to load any libraries in the trial version to test, different doors/windows/plumbing fixtures ect ?
Are these included or do you need a full subscriptions to see how the work.
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
Show us a screenshot of your entire program window please, with OPTIONS command open in the middle in the PROFILES tab.
Don't know how to do the above? Read this https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 3 of 18
coastguy84
is this what you mean ?, I can go to the load family button but cannot find the families in any of the auto cad files I can see
Message 4 of 18
coastguy84
or this one you mean ? Where this has file locations the directory it has listed doesn't exist on my system in the autodesk files
Message 5 of 18
jvpantin2
You need to download directly from Autodesk website:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-to-find-Revi...
Check version and then select correspondind content.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Message 6 of 18
loboarch
All families can be loaded from an online repository as you need them.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-9918E806-7F1A-483A-85CF-7D9EE86C1663
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 7 of 18
scott_d_davis
Go to the "Load Autodesk Families" button in the tool bar in your screen shot. We no longer install all the content by default. This Load Autodesk Families button allows you to load the individual items you might need. You can alternatively, goto the link others have provided and download and install a content pack
Scott D Davis
Sr AEC Technical Specialist
Message 8 of 18
jvpantin2
What you said @loboarch and @scott_d_davis it's right but only works since 2021.1 version. Because we don't know which release use @coastguy84 that is explained in the link I share previously.
Message 9 of 18
You can insert them directly from the cloud.
Message 10 of 18
coastguy84
thanks for the reply's, everyone, it appears that you cannon access libraries without a full subscription which seems odd as I'm only trying for the first time 2days in and don't want to outlay the expense just to test some simple features like skillion roof and laying out of floorplan with details ect  before deciding on a full subscription or not.
Message 11 of 18
You don't need a subscription to download and install content.  But I pointed you to load them directly from the cloud because you are just trying the program, no need to download and install a huge amount of data at this point.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Message 12 of 18
coastguy84
thanks have just downloaded and installed but trying to find the files now them now to be able to load in.
Message 13 of 18
Load Family > open via shortcut:
Message 14 of 18
coastguy84
shortcut doesn't show up even after running the downloaded link that says families have loaded I cant find where though
Message 15 of 18
Add them via File > Options:
Message 16 of 18
coastguy84
when i go to load family though on the main screen the file path in in options thats shows doesnt come up for me to select
Message 17 of 18
coastguy84
think ive found the links will see how i go , thanks
Message 18 of 18
coastguy84
still unable to locate libraries or what i can see in a menu on the left in selection screen i cant figure out how to place,
Have managed to save item specific ones from online and use fine though. Got me lost how to get the autodesk ones to work...
