Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is the first time i have such a problem while setting up models.
Using the survey point as a reference, my spot elevation and points (survey and base) Z values are multiplicated by 25.411....
All my units are in mm
Levels set to survey point
Spot elevation units set to survey point.
And this is what i get as a result: 153231/6030 = 25.411...
Let's say i move my survey point from Z : 0 by 1000mm.
I get the same factor in the values. How is it possible and how to solve this problem?
