Levels not showing in Elevation
DanePower8891
Message 1 of 27
DanePower8891
I have inherited some Revit files, all of which have a ground floor and ceiling plan (hence an associated level).
The levels do not show the in elevations (or sections for that matter). It is not a view setting, I have checked this, nor are they hidden by category or element. I have added new levels and these are visible. The levels exist, I just cannot view them or select them.
Any ideas?
Thanks in advance,
Dane,
Accepted solutions (3)
Replies (26)
Message 21 of 27
I had this issue when working off a template with a different massing and elevation, it threw the levels off.
Revit seems to crop the levels in 2D space depending on your view settings.
-To fix this I had to go to the 3D view and locate and move each level line closer to the object. In turn, each level line showed up on every view as it should.
Message 22 of 27
David125
How do you do that....?
Message 23 of 27
Andre_van_Keulen
In addition to this topic:
If levels ar in a scope box in a linked file, they will not be show in a section in your project. I had to copy(/monitor) them from a 3d view, and then set the scope box to none.
Message 24 of 27
Herph
I tried all of the above and nothing worked.  What finally worked for me was:
  1. Create an element (or find and existing element) on a level that isn't displayed.
  2.  Select Modify/Edit Work Plane.
  3. In the dialog box that pops up, click the "Show" button.
After I did that, all of the "missing" levels suddenly appeared.Show levels.JPG
Message 25 of 27
julie4YHUJ
Observer
Observer
This is the only solution that worked for me! Thank you!!
Message 26 of 27
Home2inc
Community Visitor
Community Visitor
MAXIMIXE EXTENTS WORKED FOR ME!
Message 27 of 27
neilmpenny1
Perfect Joe. Thank you.
