Levels in Section
Levels in Section
Levels in Section
Hello. I am seeing all sections in one view and I dont see some of them in another view. How may be the reason for that?
loboarch
The 3d extents of the level datum need to cross the view projection plane in order to see it. You may want to check the 3d extents of the level to make sure it extends far enough. You will need to look at the extents from an elevation 90deg to the ones where the level is missing in order to check this.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
