Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Issue with Revit 2017 accessing solders on Revit Server (via Vault ribbon)
Hi,  I've got an issue when I load revit2017, then log into vault (via the ribbon - logging into vault as administrator) and click on Options and then the Mapping tab, I click the + button (plus button) and choose Revit Server Folder and then the .... button it displays no folders, projects or anything.  I have revit server correctly installed, I can access Revit Server Administrator app and I can see Test Project 1 that I have created.  I have the correct .ini file on my server and client.  I can ping the servers host name and IP address from my client PC so I know all this is working correctly.  I can use the File System Folder button with no problem.  It's just my Revit Server Folder location is always blank and clicking the ... button doesn't display anything just  a white dialog box.  I am using Win7 64bit, octocore Xeon with loads of RAM, a dedicated Win Server 2012 64bit with Vault 2017 and Revit Server 2016 and all of my hardware and software is up to date.  Any ideas?  Thanks Aaron
RDAOU
@Anonymous Hello
What you described and what you did sounds all right...so before trying to guess; two things you didn't mention...just to avoid any doubt
  1. Assuming that you are browsing for the folder; When you click the ellipsis (...) to select the folders to map, there should be a check box option "USE REVIT SERVER" which should be checked to select a Revit Server folder...is it checked?
  2. Instead going via the ellipsis to browse your way to the folder; did u try to enter the path for the folder?
  3. the folder location.. is it at the root level?
  4. Which build of Revit are u using?
  5. can u post a screenshot or a screencast specifically with Vault Mapping options open? (Just to see what u r seeing ...)
Hello, I have now fixed the issue.  I think the issue may have been that I was using Revit2017 (with Vault2017) on my client PC and Revit Server 2016 on my server. I have now installed Revit Server 2017 on my server and it worked first time.  Thanks
