- Mute
- Permalink
- Report
Hi
so this is a hard one to search out so I'm resorting to posting; often I don't want the level lines to go through the model so I pull then off to the side (per slide 1) however this leads to them being pulled off in the opposite direction on the opposing view (say from north to south elevation. is there a way to manipulate this in individual elevation views
the example I show here is the overall height level at the top is moved off to to the right side in the first example but to the left in its opposite elevation. This occurs to all the levels of course if I move them too.
