Levels do not appear correctly in model
Homecad2023
Homecad2023
Hi there
I am trying to put level notation at different floor levels that are dropped at different levels.  If I pick the top of the floor the level marker shows but the text does not.  On one of the dropped panels the level marker appears and it is noted correctly.  I cannot figure out why this works for one panel and not the other 2.  If you look at the image in 3D it sort of explains it better what I am trying to do.
Any suggestions would be great, I think it is a view range setting but I tried everything
Tony
Not sure which ones not showing correctly?
Homecad2023
In 3D they look fine but if open the sample file, in the Top of Pour plan you will see my notes of which ones are not working.  I need them to appear correctly in plan view as well as 3D
Raise the view range and replace the spot elevations,
Homecad2023
thats great however I would like to have my cut plane cut through my walls so is it possible to have your cake and eat it too? 🙂
Yes you can.  Keep the view range cut plane as your have it, draw plan regions around the platform and change their cut plane independently.
Homecad2023
I did use view range at the front but I was hoping there was some other solution.
Thanks for your posts, your suggestions were great
