Levels assigned to scope box should be visible when in view range of section or elevation view
Koen5
Koen5
Assigning a level to a scope box can keep your project organized and is easier of modelling. But when creating an elevation view or section that does not cut through that scope box these levels are not visible (just like the grid elements).
When the scope box the levels are assigned to falls in the view range of the section or elevation view, the levels should still be visible in these views.
Sleepingfish_Kuo
Are you talking about this?
Koen5
Aha, This indeed makes the grids and levels visible in the selected view. Thanks, should have checked the scope box itself instead of level, grid and view properties.
