Coordination Model
Coordination Model
oladamilola
Coordination Model
oladamilola
Hello All,
I'm currently having issues with a linked Coordination Model from Navisworks not showing edges.
All i get in elevations or 3d model is a blur.
Has anyone run into said problem before and knows a work around ?
vitorbortoncello
you need to use shaded mode
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @oladamilola
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
