- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm modeling a condominium with 11 apartment building that are exactly the same. I have a Project file for the building with a Shared Location for every time (instance of link) the building is linked on the host project (the site plan with the 11 builgings). My coordinates are fine (or that appearts to me).
The issue is that I need to create four elevations and a pair of sections views for the site plan (with the whole set of building that are visibley from that section/elevation); and I have to show the current height of every building level referencing the project base point, but all the linked level display with the same elevation (the internal or shared site elevation that is active on the linked project) in spite of the level annotation is set to "Survey Point" (both in the link and in the host project).
There is something I'm doing wrong or there is a limitation with Revit? Any workaround suggested?
I can archive what I want with Spot Elevations in the host project and hidding the Levels for the links, but for 11 links in 6 views it would be a time consuming task, besides it's a very dumb way to work on BIM.
Here is some graphics examples, I recreate the situation with more simplest models (because it happends to me every time, on every project I try):
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
