how i add car parking space, walkway, green area and more on my revit project
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Just the same way you create these in all other versions of Revit - Add Sub-regions to the Topography as found in the Massing and Site tab...
Welcome to the Autodesk Community!
For a step by step process to Add Parking Components Click HERE
You can install the Site Designer plugin to create streets and sidewalks in a site design.
Additional information HERE on using Site Designer to create sidewalks, streets with or without curbs and gutters, and parking lot curbs and islands.
Let me know if you have any questions.Glad to help!
Please mark this response as "Accept as Solution" if it answers your question to benefit other users seeking similar solutions. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Go to R, Option, User interface and tick the Massing and site tab tools on.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
We wanted to check back in with you on this post. How is everything working out so far?
Please let us know if further assistance is needed from the community on this post. We are happy to help wherever possible.
Thank you and we look forward to your reply update.
Viveka CD
I am glad to hear that it worked.
Please feel free to let me know if you have any other questions or concerns!
Viveka CD
