LEVEL SYMBOL FOR PLANS
10 REPLIES 10
Message 1 of 11
18686 Views, 10 Replies
HOW CAN I SHOW THE ATTACHED BLOCK (LEVEL) ON PLANS.
IS THERE A WAY OR NOT.
AND CAN IT BE AUTOMATIC, KIND OF DETECT THE HEIGHTS FROM SECTION AS I INSERT BLOCK ON PLAN.
PLS. HELP
BJWSON
10 REPLIES 10
Message 2 of 11
You can get close with the spot dimension tool. To make exactly what you want I would make a generic annotation family with labels and just manually enter the data. Message was edited by: sdbrown
Message 3 of 11
FFL?
Finished Floor Level?
SSL?
Structural Steel Level?
Just trying to figure out what parameters you will need
wrote in message news:5545749@discussion.autodesk.com...
BLOCK ON PLAN.
PLS. HELP
BJWSON
Message 4 of 11
THE IDEA IS TO HAVE THIS LEVEL SYMBOL WORK SAME AS ROOM TAG AS I TRY TO PLACE IN THE FLOOR PLAN IT KIND OF SHOULD DETECT THE LEVEL (TOP MOST) AND (THE LEVEL OF STRUCTURE) IF ANY ONE CAN HELP IT WILL BE GREAT.
THANKS
BJWSON
Message 5 of 11
INFACT BOTH I NEED FFL & SSL
THANKS FOR LOOKING INTO IT.
BJWSON
Message 6 of 11
You'll need to:
Build your floors as a structural slab and a separate finish slab.
Create two spot elevation types - one with a FFL prefix and another with a
SSL prefix. Or create a custom spot elevation tags with the FFL and SSL
built in.
Tag each slab. - You'll need a tag for each. Stack the tags on top of each
other. Alternately the SLL tag could have no graphics and just be positioned
below the FFL tag.
Regardless - you need a tag for each object....
wrote in message news:5546965@discussion.autodesk.com...
THANKS
BJWSON
Message 7 of 11
it sounds too complicated when i see how revit works. i guess revit people should look into it.
thanks for your time and reply.
bjwson
Message 8 of 11
who ever makes your tags, should probably do this then.
wrote in message news:5548157@discussion.autodesk.com...
bjwson
Message 9 of 11
Have you tried that?
Message 10 of 11
Corsten.Au
Use Spot Elevation to Detect top and bottom of the slab..
Heres a snapshot and Screencast to show hot to edit certain parameters as well..
Spot Elevations-2.JPGSpot Elevation
Corsten
Building Designer
Message 11 of 11
Corsten.Au
Further those elevation origin can be fixed here...to show actual elevation..
Edit Tag and change elevation origin to show required Level related to Project Base, Survey and  RelativeEdit Tag and change elevation origin to show required Level related to Project Base, Survey and Relative
Corsten
Building Designer
Forma Design Contest
Technology Administrators
