I noticed the level is very far away from the model, how can I get it closer?
Solved by syman2000. Go to Solution.
Do you have scopebox setup for your project? If so, you can set the level to scopebox and it will automatically crop to the scopebox.
I don't know why you are getting that context menu. Let's try again: select any level (not the one faraway), right click, select all in project, right click again, maximize 3d extent.
right-click on the Level and not in the white area will get that menu you mentioned:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
