Level elevation relative to project base point is not correct
sed
Message 1 of 17
sed
A picture is worth a thousand words
Thanks for your help !
Replies (16)
Message 2 of 17
Check if your level's Elevation Base is set to Survey Point or Project base point.  It should be survey point to show the correct elevation above MSL.
Message 3 of 17
sed
Thanks for your answer.  Level's Elevation Base is set to Project base point so level elevation should be -910mm and not -984mm.  Am i right ?
Message 4 of 17
Mirko.Jurcevic
Yes, it should be -910mm.
Are those levels in your model and not from linked model maybe?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 5 of 17
sed
These levels are in my model.  Could it come from the fact that a dwg larger than 20 miles (33 km) was imported once in the file (it has be deleted since) ?  I know that we get a warning about accuracy of the model with such DWG files.
Message 6 of 17
hmunsell
Are the RDC and S1 Levels in your model or from a Link?
can you attach the model so we can look at it.
Howard Munsell
Message 7 of 17
HA! I must be illiterate then!
Seriously though, need more "words" from you or the RVT itself.
Message 8 of 17
sed
Sorry 🙂 Thanks for all the answers
On the picture the RDC level relative to the basepoint is -984mm
But the dimension shows -910mm
Relative to MSL basepoint elevation is 309910mm
Relative to MSL RDC level elevation is 309000mm but -984mm relative to base point
When i set the MSL elevation of RDC to 309910mm to make a test, the RDC elevation relative to the base point is -74mm
For confidentiality reasons, i can not share the file as it is.  If needed i will try to clean it before sharing.
Message 9 of 17
I'm with @hmunsell on this one.  You're pulling the dimension from the Link Level -- not the Project Level.
A picture is worth a 1000 words...
Message 10 of 17
sed
There is no Revit files linked
Message 11 of 17
Well, I'm stumped. I can't think of any other explanation
Message 12 of 17
hmunsell
a picture is worth 1000 words but a physical copy would be better in this case. Can you post the file so we can look at it?
Howard Munsell
Message 13 of 17
sed
Here is the file !
Message 14 of 17
martijn_pater
It will autocorrect when you move position (manage --> position --> relocate project) and unpin project base point, move up by zero. Or just unpin and repin project base point.
Message 15 of 17
Select Project Base Point, Unpin and Unclip  it, and then Right-Click on it an press "Move to Startup Location" from drop-down options.
Message 16 of 17
hmunsell
basically same as @barthbradley  & @martijn_pater said.... i selected the PBP and did a "Move to Internal Origin" before i started.
https://autode.sk/3fgg3EV
Howard Munsell
Message 17 of 17
sed
It works.  Thanks !
