Level 2 is Blank
Level 2 is Blank
Message 1 of 8
Level 2 is Blank
I created a floor plan on level 1 but when I select level 2 to view it. I don't see it. My walls on level 1 all go up to level 2. and my roof level is present in elevation as well. I'm trying to install a roof but nothing shows in level 2 or the roof level? REVIT 2015
Replies (7)
Message 2 of 8
ennujozlagam
@Anonymous hello, check your view range from level 2 and adjust it to negative value to view it. thanks
Message 3 of 8
If you want the walls drawn on level 1 to show on level 2, they must be taller than level 2, not just up to it.
Message 4 of 8
The wall are actually up to the roof level when I view the walls in south elevation. So they are pass level 2
Message 5 of 8
this is what my view range says, which numbers to change negative?
Message 6 of 8
Uncheck crop view. Maybe the walls are outside of the crop region.
Message 7 of 8
chrisplyler
Well you initially said that your Level 1 walls all go up to Level 2.
There are MANY reasons walls might not show up in a view. Can you post your project file for us to use? That would be the simplest way for us to identify what's wrong.
Message 8 of 8
Try to detach your walls from the slab of Level 2.......
