PointCloud to surface
1 ANTWORT 1
Nachricht 1 von 2
301 Aufrufe, 1 Antwort
I have received a pointcloud of a laser scan done for a building interior. I can see the points in Revit, once it is inserted.
How can I create a surface from that ? I have the txt file of the points, which is 273MB !
when i try ti import to revit it says "No points were found in the file.".
I need to create a 2D drawings out of this. how can i do it ?
Tags (2)
1 ANTWORT 1
Nachricht 2 von 2
steven.richter
als Antwort auf: Anonymous
Have you tried using the Dynamo 'NurbsSurface.By.Points" node for this?
