Learning Revit - Can you recommend a workflow for lighting design?
ejowalter
Message 1 of 8
ejowalter
I am continuing to learn Revit, but one thing that I haven't been able to get a handle on is a practical workflow for lighting design. I have considered exporting an IFC file and designing the lighting in Dialux Evo but I am concerned that if I design like that that I will be able to get it out of Revit but I am not quite sure how I will seamlessly get it back in 🤔.
I plan to eventually render in TwinMotion but if I design in Revit -> lighting in Dialux Evo -> render in Twin Motion, there is going to be a lot of finger-crossing when it comes to compatibility.
Can anyone suggest a better workflow?
Replies (7)
Message 2 of 8
RobDraw
I would start with asking in the MEP forum. Some of the answers from architectural types might lead to confusion.
Rob
Message 3 of 8
FacebookGroupMember
Free Basic tutorials on Revit Architecture .Subscribe for more future updates.Click the link and hit subscribe button https://youtu.be/dmLWC9MKEpE
Message 4 of 8
syman2000
You can check out some of the past Autodesk University video on these subject.
https://www.autodesk.com/autodesk-university/class/Advanced-Lighting-Design-and-Simulation-Revit-201...
Twinmotion, Lumion and Enscape are just for presentation rendering piece and won't give you accurate lighting unless those light contain IES data. You can check out Autodesk Insight product to see if this is what you are looking for.
https://www.autodesk.com/products/lighting-analysis-revit/overview
Message 5 of 8
Alfredo_Medina
I have seen offices using Elumtools for lighting calculations in Revit. I am no expert on that, but I understand that it helps to find the required lumens for a space. It works inside Revit, so that is an advantage. For rendering, you may want to try Enscape, that works inside Revit as well.
Message 6 of 8
HVAC-Novice
elumtools is THE tool for Lighting design in Revit. Excellent software and more than excellent support.
I've used it for years and it has all the features I could ever dream of. And with it being a Revit plugin, there is no efficiency lost moving data forth and back.
You also easily can implement the code compliance (egress, power density, lighting levels) plans and schedules.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 7 of 8
ejowalter
Yes, I was interested in their ability to visualize the lighting accurately so IES data would be a must.
Message 8 of 8
FacebookGroupMember
I love revit
