Leaders' End Point Gap
farzanbayat74
farzanbayat74
How to remove this gap systematically?
Simon_Weel
According to Claude: no. There are Dynamo scripts to move the endpoint afterwards.
farzanbayat74
Thank you @Simon_Weel
That's weird. What am I supposed to do with so many tags that are like this? 🤕
RLY_15
Not being a structural guy, what component is this tagging?
Tag leaders by default snap to the bounding box of the geometry, relative to the project, so a rotated family doesn't result in a 'tight' tag.
So yeah, either manual adjustment using the 'free end' leader option, or Dynamo to do the same, given you have some consistent logic to work with (Dynamo can do object-oriented bounding boxes, so that might actually work out better even without having your own placement logic).
farzanbayat74
It's tagging the plate next to it.
Ok, I got it. Thanks for your help.
Another problem that is bothering me, is that when I use tag all, tags are placed over each other, making them unreadable. I tried to use tag alignment tools, but most of the time, still manual adjustment is needed. Very time consuming …
lauri_barnhart
Thanks for posting your question, @farzanbayat74.
Just following up to see if the response by RLY_15 helped resolve your original question. If yes, please consider clicking on the 'Accept Solution' button. If you still require assistance for your additional question, please let us know by commenting here.
Thank you for being a part of the community!
Lauri | Community Manager
