Layer wrapping at the bottom of the wall
acastana06
acastana06
Dear All,
I am trying to get the condition in the picture below. Basically I want the non-core layers to wrap around the bottom of the concrete core. This is to illustrate how the thermal insulation needs to "surround" the core.
I am able to model the condition in the "Edit Assembly" window, but when I click OK, I get the errors in the picture.
Any idea what I am doing wrong?
Is there maybe another way that is the standard approach for this modeling task? Maybe by adding some sweeps at the bottom of the wall? I will later need to transform them into parts, and count (in schedule) the needed amount of thermal insulation pieces.
Many thanks in advance,
Andrei
ahjorn
  1. Your finish layer in line 9 should be "Finish 1 [4]" and not "Finish 2 [5]"
  2. All layers after Core Boundries should be given a minimum thickness. They shouldn't be zero.
Corsten.Au
yes.. you can't Wrap something with " Zero " Thickness.
and pay attention to Layer number and hierarchy..
1. Structure
2. Substrate
3. Thermal / Air Layer
4. Finish
5. Membrane Layer.
Corsten
Building Designer
RDAOU
@acastana06
Neither the Layer Thickness (which will basically be variable) nor the order/hierarchy of Layer Function  are relevant in this case... The easiest way to wrap layers around the bottom and/or of a wall works as follows:
  • All layers need to be in the CORE
  • Use 1 layer for each material - ie: Do not duplicate layers on both sides of the 250mm Cast in Situ Concrete (Otherwise you will end up with the 0 value layers)
Method is as follows:
  1. Increase Thickness of Index Layer 5 (Cast in situ Concrete) to be equal to 250mm + Thickness Layer 1+2+3
  2. Delete Index Layers 7, 8 and 9
  3. Bring Index Layers 1, 2 and 3 into the core
  4. Place Horizontal Splits
  5. Split the Cast in Situ Concrete Layer Vertically
  6. Merge Layers (See GIFF below)
Wrap Top or Bottom of a WallWrap Top or Bottom of a Wall
acastana06
Wow RDAOU!! thank you for taking the time to offer this detailed tutorial. This obviously works. As soon as I get a chance to try it in my model, I will report back and accept your solution.
Once again, many thanks for taking the time. Much appreciated.
brossettiSUR7J
Observer
Observer
Very cool trick! I just used it to create a suspended wall type for ceiling transitions. Thanks!
