Layer Display and Phasing
PhilvK
Advisor Advisor
Message 1 of 21
PhilvK
I am trying to understand what controls layer display in phasing. For example, I wanted to change all linework for New walls to blue, but when I did that under Phase Graphic Overrides, the layers disappeared and the wall is shown only in outline. Does this have something to do with the Phasing Material column?
Accepted solutions (4)
Replies (20)
Message 2 of 21
Change existing phase material to By category.
Message 3 of 21
Why don't you do this via a Rule-Based Filter applied to the View?  Filter Rule = Phase Created.
Message 4 of 21
PhilvK
Where? When I select the drop down arrow in the Phasing - Material column, I get the martial's selection list, not an option to select by Category. I am obviously missing something here.
Message 5 of 21
PhilvK
Please see my reply to ToanDN about not understanding something.
Message 6 of 21
Okay.
Then press the No Material button under Material for New. But this is going to be a global condition.
Message 7 of 21
PhilvK
I'm back to this and struggling with how to change the Phase Material to 'By Category', and figuring where and what setting makes the wall layers disappear when walls are set to existing. Any ideas where to look to figure out what I did?
Message 8 of 21
Phase Material?  You mean under Phasing Graphic Overrides?  If so, there is no BY CATEGORY.   Existing, Demolished, New and Temporary are not Categories.
...can you elaborate on what you mean by "wall layers disappear"?  Sounds like the View Detail Level is set to Coarse.
Message 9 of 21
Sounds like your Existing Category is set to "Not Displayed" in the Phase Filter dialog box for the Phase Filter the View is using.
Message 10 of 21
PhilvK
Your comment about 'coarse' is a good point. All the walls below are from Level 1 to Level 2 at 10' with the cut plane at 4'-0". My questions are:
1.  Why is the 'Existing' wall showing as it would in Coarse detail level, when the view detail level is medium, and
2.  Is there a way to have the Existing wall show in Medium detail level, only in halftone?
Message 11 of 21
Because the Cut Pattern is HIDDEN.
Message 12 of 21
PhilvK
I thought that too, but when I unhide the cut pattern, the full wall gets filled.
Message 13 of 21
Then set the Material to NO MATERIAL if that's what you want to do.
Message 14 of 21
PhilvK
Tried that, but can't figure where 'NO MATERIAL' option is to be able to set it.
Message 15 of 21
Actually, why don't you NOT Override Existing at all?  Change Existing to By Category.
Message 16 of 21
Try this and see if you like it.
...but keep in mind that this is a Global Setting. Maybe the better approach is to leave Phase Graphic Overrides alone and Override Graphics in View By Element or By Filter instead.
Message 17 of 21
By Category means No overrides.
Or just highlight the material name in the phase overrides and press Delete.
Message 18 of 21
PhilvK
How did you clear all the boxes on the EXISTING line?
Message 19 of 21
Clear Overrides button.
...@ bottom left
Message 20 of 21
PhilvK
Thank you, thank you !
