Launch snu revit
Launch snu revit
Message 1 of 9
Launch snu revit
thying to install the pug in for "launch snu revit".
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Is this the corrcet page to view?
Exist only for 17 and 18 verions?
Thank's
Accepted solutions (3)
Replies (8)
Message 2 of 9
Do not have the add-in but the command "space" for thermal analysis.
Is right?
Message 3 of 9
The Space Naming Utility can be download from manage.autodesk.com by clicking on your subscription entitlement and select Updates & Add-ons.
Message 4 of 9
Only for 17 seems now?
Thank's!
Message 5 of 9
I have access to 2017, then under Product Ehnancements in the Quick Links I have 2015, 2014, 2013.  Not sure where 2016 went to.
With 2018 it is built in with the Space & Zones Panel.
Message 6 of 9
Space Naming Utility for Revit 2016 is on the App Store...  https://apps.autodesk.com/RVT/en/Detail/Index?id=855855288022447765&appLang=en&os=Win32_64
You have to have a Subscription/Education License to gain access to it.
Message 7 of 9
Sorry,
the garanty the presence of "launch snu" is space in annotate tab?
Because I'v installed Space Naming Utility in 2017 but don't find SNU in add.in.
Thank's
Message 8 of 9
You will want to check where it got installed then....
Message 9 of 9
Now I have launch in add-in but not "space naming" command.
Hope go in any case.
However thanks! 😉 :))
