Revit interface
Revit interface
Revit interface
I have a prob on my revit app that I recently installed lines look thick when I zoom In .... Task bar and all the icons look fuzzy or blurry...
sureshchotrani
Hi @Anonymous
Kindly know the Revit version, windows( eg 7, 8 or 10) & graphic card you are using.
Was Revit working properly prior or you are facing issues with new installation.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Revit 2018 / windows 10 ... gtx geforce 1060 ( gpu)
No the prob happened when I installed the revit 18 I had the 2016 and I didnt face the prob back the.
sureshchotrani
Can you please apply the updates to make Revit 2018 to Revit 2018.1. You can get the updates from Autodesk APP or via manage.autodesk.com?
Okay ill see if that solves my prob
I updated.. Nothing happened still the same prob ..
sureshchotrani
Can you please help with screenshot?
Is this happening with a particular file or in any Revit session?
